Volume Lighting V8619 Single Light LED 35,000 Hour Lamp Life Recessed Retrofit F
main picture
We compared price of Volume Lighting V8619 Single Light LED 35,000 Hour Lamp Life Recessed Retrofit F across hundreds of online stores. We found Volume Lighting V8619 Single Light LED 35,000 Hour Lamp Life Recessed Retrofit F in 1 store with lowest price $88.50 in Build.com. For detailed price comparison of Volume Lighting V8619 Single Light LED 35,000 Hour Lamp Life Recessed Retrofit F check table below.
Merchant Price -
Build.com [show price]
Volume Lighting V8619 Single Light LED 35,000 Hour Lamp Life Recessed Retrofit F description from Build.com
Volume Lighting, V8619, Trim And Housing Package, Recessed Lights,White Volume Lighting V8619 Energy Efficient Led 5-6 Recessed Retrofit This High Performance Led Recessed Retrofit Delivers 800 Lumens With Only 13 Watts Of Energy And An Estimated 35,000 Hour Lamp Life. There Is Nothing Like This On The Market! Features: White Finish With Frosted Lens Cover - Light Weight Module That Is Completely Sealed - Includes Driver, Led Lamps Amp; Trim Ring - Ul Rated For Wet Locations - Engery Efficient Fixture - Dimmable Up To 10% - Can Be Replaced With An Incandescent Bulb - Specifications: Height: 3.625 - Width: 7.5 - Number Of Bulbs: 1 (Included) - Bulb Base: Medium - Bulb Type: Led - Max. Watts: Led Is 13W - Incandescent Is 75W - Lumens Output: 800 - Input: 120V 60Hz/50Hz - Color Temp.: 3,000K - Lamp Life: 35,000 Hours (Estimated) -
Customer review
Volume Lighting Volume Lighting V8619 Single Light LED 35,000 Hour Lamp Life Recessed Retrofit F is just amazing! It is much worth than what you pay at Build.com.
